nrf52 TWI excess current consumption
Hello, I use an I2C device to wake up a nrf52 microcontroler. If I just use the init function
static ret_code_t twi_master_init(void)
    ret_code_t ret;
    const nrf_drv_twi_config_t config =
       .scl                = 6,
       .sda                = 5,
       .frequency          = NRF_TWI_FREQ_400K,
       .interrupt_priority = APP_IRQ_PRIORITY_LOW
    do
        ret = nrf_drv_twi_init(&m_twi_master, &config, NULL);
        if(NRF_SUCCESS != ret)
        nrf_drv_twi_enable(&m_twi_master);
    }while(0);
    return ret;
and then
	softdevice_init();
	scheduler_init();
	twi_master_init();
	sd_power_system_off();
the system has a 0.1mA (or less, but that's not the point today) sleep current.
But if I add a line (to disable the TWI peripheral, and it's the same when I programm a data transfer)
  softdevice_init();
  scheduler_init();
  twi_master_init();
  nrf_drv_twi_uninit(&m_twi_master);
the system current is 0.6mA. I've checked the SCL and SDA lines for pull ups issues, but there are at a high level (there are 10k pull ups outsde the nrf52), so that I don't think it's the case. I've added
NRF_TWI0->ENABLE=TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
To force the peripheral off, but nothing better happens. Iv'e set the Pins SDA and SCL as input, outputs or float, but nothing more happens too. I've added those lines too :
nrf_twi_task_set(m_twi_master.p_reg,NRF_TWI_TASKS_STOP);
while(!nrf_twi_event_check(m_twi_master.p_reg,NRF_TWI_EVENTS_STOPPED ));
But again, nothing. There must be something I've missed, but I don't know what...
1 2 3 4
