ble_app_beacon wake up with button press on dev kit
I just made it to upload the example to the device. I'm new into firmware development btw.
I changed the timeout so the beacon will stop advertising after 120 seconds but I want it to wake up when I press the button 1.
Can you guide me in this process? And also I want it to ask.. when device stop advertising using the APP_CFG_NON_CONN_ADV_TIMEOUT parameter, does it enter to a low power consumption mode?
Thanks!
  • Hi Carlos
    Yes, when the advertising times out, the nRF51 will enter low power state, where current consumption is 3uA-4uA
    To detect button presses, check out the bsp library, tutorial and documentation
  • Hi Carlos
    If you look at e.g. the ble_app_bps example in the nRF5 SDK 11.0.0, you can find an event BLE_GAP_EVT_TIMEOUT being handled, which is fired from the softdevice when the advertising times out. To receive softdevice events, you need however to define a handler when initializing the softdevice. This handler needs to be defined in the ble_app_beacon example when calling the SOFTDEVICE_HANDLER_INIT macro. Then you can capture the BLE_GAP_EVT_TIMEOUT event in a similar way as done in the ble_app_bps.
  • Hi Carlos
