Current peak on nRF52
Hi, I make some tests on power consumption of nRF52 with evaluation board and I remark some peak on the current. it's appeared that this peak is generate by DEC4 output (see picture below. current in pink and Vdec4 in yellow).
image description image description
Is it normal ? and is there a way to eliminate this peak ?
Thanks.
  • Hi Victorien
    nRF52 has internal power management system that enables the internal regulators dependent on how much power the on-chip peripherals need. The internal regulator is enabled to charge up a capacitor. When capacitor is charged up, the regulator is disabled to save power. The capacitor feeds the peripherals with power for a period of time until a minimum voltage level is reached, then the regulator is enabled again to charge up the capacitor. That is what I suspect you are seeing.
    This is also explained on this thread.
  • Hi Victorien
