Is there any way to test an external PCB o flex antenna with the nrf52 DK? Thanks in advance.
The DK has a SWF connector (J1, part number: MM8130-2600) that you can connect to your external antenna. Make sure you antenna is tuned with 50 Ohm impedance.
Thank you for your answer! Does it make sense if I disolder J1 and solder directly the antenna to the pad?
You can do that, but if you want to optimize the antenna performance you would need to tune it.
Perfect, thanks a lot!
