Hello, I tried to do DFU using MCP 3.10.0.14 and I'm getting the error:
"Error during firmware upload. Timeout while waiting for response for START DFU"
How do I increase timeout in MCP??
It seems to happen when I try to upload bigger firmware.
I am not sure if you can increase this timeout, but have you tried with faster connection interval? how big file are you talking about?
Thank you for tip. But I started from standard example (examples\dfu\bootloader\pca10040\dual_bank_ble_s132\arm5_no_packs\dfu_dual_bank_ble_s132_pca10040.uvprojx
) and I did not touch the speed. It was set to fairly fast:
MIN_CONN_INTERVAL (uint16_t)(MSEC_TO_UNITS(15, UNIT_1_25_MS))
MAX_CONN_INTERVAL (uint16_t)(MSEC_TO_UNITS(30, UNIT_1_25_MS))
I tried to set 7.5 and 15. And the error is same.
Also it seems the error is before programming starts - so I assume what takes really long is erasing 360KB of Flash.. I think this is the bottle neck on FW side and it is in flash which is fixed...
can you try nRFConnect and see if this is the same case there. If so, then i will take your hex files and talk to the engineer of MCP and nRFConnect.
I tried to upload the same zip file using nRF connect 4.3.2 on android K and it worked :). So the problem seems to be only in MCP. I looked on nRF connect v 1.0 also for PC - but I do not see the button for start DFU.
