Problem with the NRF_DRV_TWI_INSTANCE(0) (twi/i2c)
Hello!
I want to connect the MCP9808 with the nrf52832. Therefor I use i2C.
My example on the nrf52832 is the:
<nRF5_SDK_v11_0_0 folder>\examples\ble_peripheral\experimental_ble_app_eddystone\
Now, I have written the code of the twi_sensor example in the eddystone example.
But, there is an error on:
static const nrf_drv_twi_t m_twi_mcp9808 = NRF_DRV_TWI_INSTANCE(0);
error: use undeclared identifier ‘TWI0_USE_EASY_DMA’
error: use undeclared identifier ‘TWI0_INSTANCE_INDEX’
What is wrong?
I have include the "nrf_drv_twi.h" with the identification.
My main Code:
    #include <stdbool.h>
    #include <stdint.h>
    #include "ble_advdata.h"
    #include "nordic_common.h"
    #include "softdevice_handler.h"
    #include "bsp.h"
    #include "app_timer.h"
    #include "nrf_temp.h"
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    /*Pins to connect shield. */
    #define DEVICE_SCL_PIN 0
    #define DEVICE_SDA_PIN 1
    /*Common addresses definition for accelereomter. */
    #define TEMP_ADDR        (0x18U)
    #define TEMP_REG_RFU   	 0x00U
    #define TEMP_REG_CONFIG  0x01U
    #define TEMP_REG_TUPPER  0x02U
    #define TEMP_REG_TLOWER  0x03U
    #define TEMP_REG_TCRIT   0x04U
    #define TEMP_REG_TEMP	   0x05U
    #define TEMP_REG_MID	   0x06U
    #define TEMP_REG_DID	   0x07U
    #define TEMP_REG_RESR    0x08U
    // [max 255, otherwise "int16_t" won't be sufficient to hold the sum
    //  of accelerometer samples]
    #define NUMBER_OF_SAMPLES 20
    #define IS_SRVC_CHANGED_CHARACT_PRESENT 0                                 /**< Include the service changed characteristic. If not enabled, the server's database cannot be changed for the lifetime of the device. */
    #define CENTRAL_LINK_COUNT              0                                 /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
    #define PERIPHERAL_LINK_COUNT           0                                 /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
    #define APP_CFG_NON_CONN_ADV_TIMEOUT    0                                 /**< Time for which the device must be advertising in non-connectable mode (in seconds). 0 disables the time-out. */
    #define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(1000, UNIT_0_625_MS) /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100 ms and 10.24 s). */
    // Eddystone common data
    #define APP_EDDYSTONE_UUID              0xFEAA                            /**< UUID for Eddystone beacons according to specification. */
    #define APP_EDDYSTONE_RSSI              0xEE                              /**< 0xEE = -18 dB is the approximate signal strength at 0 m. */
    // Eddystone UID data
    #define APP_EDDYSTONE_UID_FRAME_TYPE    0x00                              /**< UID frame type is fixed at 0x00. */
    #define APP_EDDYSTONE_UID_RFU           0x00, 0x00                        /**< Reserved for future use according to specification. */
    #define APP_EDDYSTONE_UID_ID            0x01, 0x02, 0x03, 0x04, \
                                            0x05, 0x06                        /**< Mock values for 6-byte Eddystone UID ID instance.  */
    #define APP_EDDYSTONE_UID_NAMESPACE     0xAA, 0xAA, 0xBB, 0xBB, \
                                            0xCC, 0xCC, 0xDD, 0xDD, \
                                            0xEE, 0xEE                        /**< Mock values for 10-byte Eddystone UID ID namespace. */
    // Eddystone URL data
    #define APP_EDDYSTONE_URL_FRAME_TYPE    0x10                              /**< URL Frame type is fixed at 0x10. */
    #define APP_EDDYSTONE_URL_SCHEME        0x00                              /**< 0x00 = "http://www" URL prefix scheme according to specification. */
    #define APP_EDDYSTONE_URL_URL           0x6e, 0x6f, 0x72, 0x64, \
                                            0x69, 0x63, 0x73, 0x65, \
                                            0x6d,0x69, 0x00                   /**< "nordicsemi.com". Last byte suffix 0x00 = ".com" according to specification. */
    // Eddystone TLM data
    #define APP_EDDYSTONE_TLM_FRAME_TYPE    0x20                              /**< TLM frame type is fixed at 0x20. */
    #define APP_EDDYSTONE_TLM_VERSION       0x00                              /**< TLM version might change in the future to accommodate other data according to specification. */
    #define APP_EDDYSTONE_TLM_BATTERY       0x00, 0xF0                        /**< Mock value. Battery voltage in 1 mV per bit. */
    #define APP_EDDYSTONE_TLM_TEMPERATURE   0x0F, 0x00                        /**< Mock value. Temperature [C]. Signed 8.8 fixed-point notation. */
    #define APP_EDDYSTONE_TLM_ADV_COUNT     0x00, 0x00, 0x00, 0x00            /**< Running count of advertisements of all types since power-up or reboot. */
    #define APP_EDDYSTONE_TLM_SEC_COUNT     0x00, 0x00, 0x00, 0x00            /**< Running count in 0.1 s resolution since power-up or reboot. */
    #define DEAD_BEEF                       0xDEADBEEF                        /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define APP_TIMER_PRESCALER             0                                 /**< Value of the RTC1 PRESCALER register. */
    #define APP_TIMER_OP_QUEUE_SIZE         4                                 /**< Size of timer operation queues. */
    static ble_gap_adv_params_t m_adv_params;                                 /**< Parameters to be passed to the stack when starting advertising. */
    //static uint8_t eddystone_url_data[] =   /**< Information advertised by the Eddystone URL frame type. */
    //    APP_EDDYSTONE_URL_FRAME_TYPE,   // Eddystone URL frame type.
    //    APP_EDDYSTONE_RSSI,             // RSSI value at 0 m.
    //    APP_EDDYSTONE_URL_SCHEME,       // Scheme or prefix for URL ("http", "http://www", etc.)
    //    APP_EDDYSTONE_URL_URL           // URL with a maximum length of 17 bytes. Last byte is suffix (".com", ".org", etc.)
    /** @snippet [Eddystone UID data] */
    //static uint8_t eddystone_uid_data[] =   /**< Information advertised by the Eddystone UID frame type. */
    //    APP_EDDYSTONE_UID_FRAME_TYPE,   // Eddystone UID frame type.
    //    APP_EDDYSTONE_UID_NAMESPACE,    // 10-byte namespace value. Similar to Beacon Major.
    //    APP_EDDYSTONE_UID_ID,           // 6-byte ID value. Similar to Beacon Minor.
    //    APP_EDDYSTONE_UID_RFU           // Reserved for future use.
    static uint8_t eddystone_tlm_data[] =   /**< Information advertised by the Eddystone TLM frame type. */
        APP_EDDYSTONE_TLM_FRAME_TYPE,   // Eddystone TLM frame type.
        APP_EDDYSTONE_TLM_VERSION,      // Eddystone TLM version.
        APP_EDDYSTONE_TLM_BATTERY,      // Battery voltage in mV/bit.
        APP_EDDYSTONE_TLM_TEMPERATURE,  // Temperature [C].
        APP_EDDYSTONE_TLM_ADV_COUNT,    // Number of advertisements since power-up or reboot.
        APP_EDDYSTONE_TLM_SEC_COUNT     // Time since power-up or reboot. 0.1 s increments.
    typedef struct
    		uint8_t MSB_Data;
    		uint8_t LSB_Data;
    } sample_t;
    sample_t Temp_Sensor;
    /* Buffer for samples. */
    static sample_t m_sample_buffer[NUMBER_OF_SAMPLES] = {0};
    /* Indicates if reading operation from accelerometer has ended. */
    static volatile bool m_xfer_done = true;
    /* Indicates if setting mode operation has ended. */
    static volatile bool m_set_mode_done = false;
    /* TWI instance. */
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in]   line_num   Line number of the failing ASSERT call.
     * @param[in]   file_name  File name of the failing ASSERT call.
    /**@brief Function for initializing the advertising functionality.
     * @details Encodes the required advertising data and passes it to the stack.
     *          Also builds a structure to be passed to the stack when starting advertising.
        uint32_t      err_code;
    		int32_t				temp;
    		uint8_t 			temp_a;
    		uint8_t 			temp_b;
        ble_advdata_t advdata;
        uint8_t       flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        ble_uuid_t    adv_uuids[] = {{APP_EDDYSTONE_UUID, BLE_UUID_TYPE_BLE}};
        uint8_array_t eddystone_data_array;                             // Array for Service Data structure.
    /** @snippet [Eddystone data array] */
    		sd_temp_get(&temp);
    		temp_a = temp;
    		temp_b = temp;
    		temp_a >>= 2;
    		temp_b <<= 6;
    		eddystone_tlm_data [4] = temp_a;
    		eddystone_tlm_data [5] = temp_b;
        eddystone_data_array.p_data = (uint8_t *) eddystone_tlm_data;   // Pointer to the data to advertise.
        eddystone_data_array.size = sizeof(eddystone_tlm_data);         // Size of the data to advertise.
        ble_advdata_service_data_t service_data;                        // Structure to hold Service Data.
        service_data.service_uuid = APP_EDDYSTONE_UUID;                 // Eddystone UUID to allow discoverability on iOS devices.
        service_data.data = eddystone_data_array;                       // Array for service advertisement data.
        // Build and set advertising data.
        memset(&advdata, 0, sizeof(advdata));
        advdata.name_type               = BLE_ADVDATA_NO_NAME;
        advdata.flags                   = flags;
        advdata.uuids_complete.uuid_cnt = sizeof(adv_uuids) / sizeof(adv_uuids[0]);
        advdata.uuids_complete.p_uuids  = adv_uuids;
        advdata.p_service_data_array    = &service_data;                // Pointer to Service Data structure.
        advdata.service_data_count      = 1;
        err_code = ble_advdata_set(&advdata, NULL);
        // Initialize advertising parameters (used when starting advertising).
        memset(&m_adv_params, 0, sizeof(m_adv_params));
        m_adv_params.type        = BLE_GAP_ADV_TYPE_ADV_NONCONN_IND;
        m_adv_params.p_peer_addr = NULL;                                // Undirected advertisement.
        m_adv_params.fp          = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval    = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.timeout     = APP_CFG_NON_CONN_ADV_TIMEOUT;
        uint32_t err_code;
        err_code = sd_ble_gap_adv_start(&m_adv_params);
        uint32_t err_code;
    // see nrf_sdm.h for more details
    nrf_clock_lf_cfg_t clock_lf_cfg =
        .source = NRF_CLOCK_LF_SRC_RC,
        .rc_ctiv = 16, // Interval in 0.25 s, 16 * 0.25 = 4 sec
        .rc_temp_ctiv = 2, // Check temperature every .rc_ctiv, but calibrate every .rc_temp_ctiv
        .xtal_accuracy = NRF_CLOCK_LF_XTAL_ACCURACY_250_PPM,
        // Initialize the SoftDevice handler module.
        SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
        ble_enable_params_t ble_enable_params;
        err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                        PERIPHERAL_LINK_COUNT,
                                                        &ble_enable_params);
        //Check the ram settings against the used number of links
        CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
        // Enable BLE stack.
        err_code = softdevice_enable(&ble_enable_params);
    /**@brief Function for doing power management.
    static void power_manage(void)
        uint32_t err_code = sd_app_evt_wait();
     * @brief Function for setting active mode on mcp9808.
    void mcp9808_set_mode(void)
        ret_code_t err_code;
        uint8_t reg[1] = {TEMP_REG_TEMP};
        err_code = nrf_drv_twi_tx(&m_twi_mcp9808, TEMP_ADDR, reg, sizeof(reg), false);
        while(m_set_mode_done == false);
     * @brief TWI events handler.
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
        static sample_t m_sample;
        switch(p_event->type)
            case NRF_DRV_TWI_EVT_DONE:
                if ((p_event->type == NRF_DRV_TWI_EVT_DONE) &&
                    (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_TX))
                    if(m_set_mode_done != true)
                        m_set_mode_done  = true;
                        return;
                    m_xfer_done = false;
                    /* Read 4 bytes from the specified address. */
                    err_code = nrf_drv_twi_rx(&m_twi_mcp9808, TEMP_ADDR, (uint8_t*)&m_sample, sizeof(m_sample));
                    Temp_Sensor = m_sample;
                    m_xfer_done = true;
 void twi_init (void)
    const nrf_drv_twi_config_t twi_mcp9808_config = {
			.scl                = DEVICE_SCL_PIN,
       .sda                = DEVICE_SDA_PIN,
       .frequency          = NRF_TWI_FREQ_100K,
       .interrupt_priority = APP_IRQ_PRIORITY_HIGH
    err_code = nrf_drv_twi_init(&m_twi_mcp9808, &twi_mcp9808_config, twi_handler, NULL);
    nrf_drv_twi_enable(&m_twi_mcp9808);
     * @brief Function for application main entry.
        uint32_t err_code;
        // Initialize.
        APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
        err_code = bsp_init(BSP_INIT_LED, APP_TIMER_TICKS(100, APP_TIMER_PRESCALER), NULL);
     //  	err_code = 0x0;
        ble_stack_init();
        advertising_init();
        twi_init();
    //    LEDS_ON(LEDS_MASK);
        // Start execution.
        advertising_start();
    		nrf_gpio_pin_set(2);
    	  mcp9808_set_mode();
    	  uint8_t reg = TEMP_REG_TEMP;
        ret_code_t err_code_sens;
        // Enter main loop.
        for (;; )
    			do
                __WFE();
            }while(m_xfer_done == false);
            err_code_sens = nrf_drv_twi_tx(&m_twi_mcp9808, TEMP_ADDR, &reg, sizeof(reg), true);
            APP_ERROR_CHECK(err_code_sens);
            power_manage();
    	    advertising_init();
Thanks for answer!
  • go to nrf_drv_config.h file in your project and change
    #define TWI0_ENABLED 0
    to
    #define TWI0_ENABLED 1
  • Thanks, but the errors do not disappear.
    #if (TWI0_ENABLED == 1)
    #define TWI0_USE_EASY_DMA 0
    #define TWI0_CONFIG_FREQUENCY    NRF_TWI_FREQ_100K
    #define TWI0_CONFIG_SCL          0
    #define TWI0_CONFIG_SDA          1
    #define TWI0_CONFIG_IRQ_PRIORITY APP_IRQ_PRIORITY_LOW
    #define TWI0_INSTANCE_INDEX      0
  • It shows the same errors as before.
    Build Output:
    .\_build\nrf52832_xxaa_s132.axf: Error: L6218E: Undefined symbol nrf_drv_twi_enable (referred from main.o).
    .\_build\nrf52832_xxaa_s132.axf: Error: L6218E: Undefined symbol nrf_drv_twi_init (referred from main.o).
    .\_build\nrf52832_xxaa_s132.axf: Error: L6218E: Undefined symbol nrf_drv_twi_rx (referred from main.o).
    .\_build\nrf52832_xxaa_s132.axf: Error: L6218E: Undefined symbol nrf_drv_twi_tx (referred from main.o).
    Not enough information to list image symbols.
    Finished: 1 information, 0 warning and 4 error messages.
    ".\_build\nrf52832_xxaa_s132.axf" - 4 Error(s), 1 Warning(s).
  • are you sure that you are doing this in the right nrf_drv_config.h file. You should open the one that is included in your project. If you change the define then it is practically not possible to get this error.
  • Now, the errors of the Error List are disappeared. Sorry, there was a little mistake in Keil. But the Build Output is like above (with the errors).
