Hi, just want to make sure: is it possible to merge UICR values into hex so that I can load some values there during production in a single flashing stage?
thanks best regards
thanks best regards
The mergehex tool is provided by Nordic. You can use it to merge two hex files. You will find many posts about it, for instance this one.
The mergehex program is part of the nRF5x Command Line Tools. You can download it from here. It is available for Windows, Linux and Mac OS X.
You can also use many other "generic" software, like SRecord for instance.
The UICR registers at cannot be erased without completely erasing the chip (using a debugger), but once erased, you write to it in exactly the same way as any other part of the flash.
