I'm having an issue when trying to update the bootloader itself: NRF_UICR->NRFFW[1] returns 0xFFFFFFFF, which means I can't use the MBR command to swap bootloaders (see doc).
So I have a few questions: Why is this address not set by the bootloader provided in the SDK (at least the BLE one, I found some stuff done for the ANT bootloader)?
I guess I can reproduce the method used to set NRF_UICR->NRFFW[0] (bootloader address) to set this value when programming the MCU. But can I set NRF_UICR->NRFFW[1] from the bootloader or application code?
Thanks in advance
EDIT: I found some documentation to write UICR registers here. I'll start to work on it and write about a solution here.
EDIT 2: the BOOTLOADER_MBR_PARAMS_PAGE_ADDRESS is actually defined and used in bootloader_settings.c. Two sections called mbrParamsPage and uicrMbrParamsPageAddress are used to link some space to the right address. Then my issue comes from the link script...
