Sleep on long button press wakes up automatically
Hi
Using an nRF52832 and SDK11, I have the following issue:
I want to use button 0 with a regular push for functionality and a long press to go to sleep. The detection of long and short pushes work, and the button is configured to cause a wakeup. Problem is that when going to sleep during a long press, the system automatically powers back up due to the button still being pressed.
Is there any way to avoid the wakeup when the button is still pressed and wait till a new flank (so first release, then push again)
Here's my relevant code:
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
    err_code = bsp_event_to_button_action_assign(0, BSP_BUTTON_ACTION_LONG_PUSH, BSP_EVENT_LONG_KEY_0);
    uint32_t err_code;
    switch (event)
    {   case BSP_EVENT_KEY_0:
            someFunction();
        case BSP_EVENT_LONG_KEY_0:
            sleep_mode_enter();
    // Prepare wakeup buttons.
  • Quote from Product spec, you are right, DETECT is level triggered not edge trigged, my bad, thanks for correcting
    When the correct level is detected on any such configured pin, the sense mechanism will set the DETECT signal high. Each pin has a separate DETECT signal, and the default behaviour, as defined by the DETECTMODE register, is that the DETECT signal from all pins in the GPIO Port are combined into a common DETECT signal that is routed throughout the system
