nRF52832 P0.21/RESET pin
How is the functionality of P0.21 in nRF52832? It is configured as RESET after turning on the device, right? Is there any way to change it in a way that that the chip starts working even when this pin is low?
-Vala
  • Yes it's in the manual. Set PSELRESET registers and reset the chip. They are retained and will disable reset.
    Please tell me if I'm doing anything wrong with disabling the RESET. Using nrfjprog I erase the UICR and after that the all the registers including two PSELRESET registers are set to 0xFFFFFFFF:
    nrfjprog --eraseuicr --family nrf52 Erasing UICR flash area. Applying system reset.
    nrfjprog --memrd 0x10001200 --family nrf52 0x10001200: FFFFFFFF |....|
    nrfjprog --memrd 0x10001204 --family nrf52 0x10001204: FFFFFFFF |....|
    But when I restart the device it again does not start executing until I manually set the P0.21 pin. Any idea?
  • So if you read back the values are they still FFFFFFFF? If not then something must be rewriting them
    you probably have CONFIG_GPIO_AS_PINRESET defined.
  • Thanks for your answer RK. You are right. Here is what I get: nrfjprog --eraseuicr --family nrf52 Erasing UICR flash area. Applying system reset.
    nrfjprog --memwr 0x100010FC --val 0x00000001 --family nrf52 Parsing parameters. Writing.
    nrfjprog --memrd 0x100010FC --family nrf52 0x100010FC: 00000001 |....|
    nrfjprog -r --family nrf52 Applying system reset. Run.
    nrfjprog --memrd 0x10001204 --family nrf52 0x10001204: 00000015 |....|
    After the reset the value of PSELRESET is again 0x00000015. It's interesting because I do not have anything more than a couple of lines for toggling the IOs in my code, which is a modification of the blinky example. Is there anything else I should check?
