SDK12 DFU examples compilation error
When I try to compile DFU examples, I get the following errors :
  1. "..\..\dfu_public_key.c(20): error: #35: #error directive: "Debug public key not valid for production. Please see github.com/.../README.md to generate it"
  2. "#error "Debug public key not valid for production. Please see github.com/.../README.md to generate it"
  3. ..\..\..\..\..\components\libraries\ecc\ecc.c(25): error: #5: cannot open source input file "uECC.h": No such file or directory
Do you have the same behaviour?
  • The uECC library is an external library that is not a part of the SDK and it must be installed by the user. You can find a step-by-step install guide on this infocenter page.
  • Not answers, just guesses:
    Possibly, see the known problems with v12 sticky in this forum.
    Possibly #3 is a filename capitalization error? On my system, find . -iname *ECC.h yields only ./components/libraries/ecc/ecc.h. Maybe the new version changed the filename (but not in some Makefiles)?
    Are these error messages all from the same problem? Better if you state the environment and give verbatim error messages.
  • error 3. is due to missing micro-ecc library - the link I've posted above describes bootloader setup and includes steps to download and cross compile this library.
    errors 1 and 2 are due to lack of SDK customization using developer private key the link I've posted above also includes chapter on generating and adding this key.
    I hope that it's more clear this time.
  • @keton: Is this related to this question?
1 2
