How to use the watchdog when DFU
Hi
I opened the Watchdog in the user application,and do nothing in the bootloader.Then when I use DFU,the CPU reset appears.How can I to deal with it?
And when I upgrade willful termination APP(nRF Toolbox),the CPU(nRF52832)is down,and can't work.Do you have any suggestions on how to solve this fault tolerance?
Thank you!
  • One thing you may consider what I have applied is the WDT settings in the nrf_drv_config.h I use
    #define WDT_CONFIG_BEHAVIOUR     NRF_WDT_BEHAVIOUR_PAUSE_SLEEP_HALT
    Since bootloader with bluetooth most of the time waits for events, no timeout is occuring for the duration of the update process. Thus far I have implemented 10 second and 30 second timeouts for watchdog and both successfully have enabled to finish the dfu process. I am using nRF51 and legacy dfu.
