How to use the watchdog when DFU
Hi
I opened the Watchdog in the user application,and do nothing in the bootloader.Then when I use DFU,the CPU reset appears.How can I to deal with it?
And when I upgrade willful termination APP(nRF Toolbox),the CPU(nRF52832)is down,and can't work.Do you have any suggestions on how to solve this fault tolerance?
Thank you!
  • Ok. thanks.
    Actually I was getting an issue while dfu. when nrf set to boot mode it resets due to WDT and app started working normally as I have set WDT reload value to 3000.
    after I have changed it to 60000( 60 sec ), all works fine yeserday. I have set nrf to boot mode then completed dfu process and app updated.
    Can you please explain the reason?
  • The bootloader should feed the WDT in an infinite loop, see
    /**@brief Continually sleep and process tasks whenever woken.
    static void loop_forever(void)
        while (true)
            //feed the watchdog if enabled.
            nrf_bootloader_wdt_feed();
            app_sched_execute();
            if (!NRF_LOG_PROCESS())
                wait_for_event();
    as well as start a timer that feeds the WDT periodically
    void nrf_bootloader_wdt_init(void)
        static bool initialized = false;
        if (initialized)
            return;
        if (nrf_wdt_started())
            uint32_t wdt_ticks = nrf_wdt_reload_value_get();
            NRF_LOG_INFO("WDT enabled CRV:%d ticks", wdt_ticks);
            //wdt_ticks must be reduced to feed the watchdog before the timeout.
            uint32_t reduced_timeout_ticks = MAX((int32_t)wdt_ticks - MAX_FLASH_OP_TIME_TICKS,
                                                 NRF_BOOTLOADER_MIN_TIMEOUT_TICKS);
            /* initial watchdog feed */
            wdt_feed();
            NRF_LOG_INFO("Starting a timer (%d ticks) for feeding watchdog.", reduced_timeout_ticks);
            nrf_bootloader_wdt_feed_timer_start(reduced_timeout_ticks, wdt_feed_timer_handler);
            NVIC_EnableIRQ(WDT_IRQn);
            NRF_LOG_INFO("WDT is not enabled");
        initialized = true;
    static void wdt_feed_timer_handler(void)
        NRF_LOG_INFO("Internal feed");
        wdt_feed();
    Can you debug the bootloader when the WDT interval is set to 3seconds and check that you enter the wdt_feed_timer_handler()?
  • yes I'll check.
    today I have checked with different WDT reload values. It's working fine with 15000 but not below than that.
