follow the tutorial I'm stuck in the step of removing "retarget" I don't have such option
I have this one. Should I just remove retarget.c directly via context menu in project explorer?
The tutorial explains how to do it with packs.
I have included the SEGGER_RTT files in my no-pack project and did not have to remove the retarget.c file, so see if you are able to do it without removing it. If you for some reason need to remove it you do it by right clicking on the file in the project window and choose remove.
If I leave retarget.c file it raises error
I'm not sure could I do this way but It worked. I just comment those two raws in retarget.c file. And the errors are disappear
It solved by comment FILE __stdout; FILE __stdin;
in retarget.c file
You should rather remove the file from your project or do the changes on a copy of the file.
removing file also worked
