nrf51822 ble UART Random disconnection
Hello all!
Sorry for what might seems an obvious question, my skills are what they are :-). We have a small circuit based on nrf51822 chip.
Our software is currently working fine but we are doing several tests to make sure some unprobable events will not have strong negative impact.
The goal of our circuit is to monitor 4 inputs and, if some conditions are met, save on an external memory and then send information over ble UART protocol.
to send data over ble UART, we use this function: ble_nus_buffer_send(Message, sizeof(Message))
In details:
U8 ble_nus_buffer_send(uint8_t * abuffer, uint32_t alength)
uint32_t sublength, err_code;
if(m_conn_handle == BLE_CONN_HANDLE_INVALID) return 0;
LED_Off();
while(alength)
if(alength > BLE_NUS_MAX_DATA_LEN)
  sublength = BLE_NUS_MAX_DATA_LEN;
  sublength = alength;
BtDataTxComplete = 0;
err_code = ble_nus_string_send(&m_nus, abuffer, sublength);
if(err_code != NRF_SUCCESS) return 0;
while(BtDataTxComplete == 0) {}; //nrf_delay_ms(1);
abuffer += sublength;
alength -= sublength;
LED_On();
return 1;
Some of you might recognize the nrf_UART code here.
What we have found is that, we we are sending many strings in a loop using this function and we randomly abruptly disconnect (by pressing disconnect button) from the receiver side (nrfUART android app. for ex.), the code stay stuck on the function (ble_nus_buffer_send) until next ble connection happens. During this time, the module is not doing what it is suppose to do (monitor IO and record events for example)
It's hard to look for similar issue in this forum so maybe some of you could help us make sure that when a brutal disconnection happens, the code don't wait for that function (exit the message transmission loop).
Thank you
Francois
  • We often see selecting disconnect in an Android app doesn't guarantee the Android will actually disconnect. So the nRF will think it is still in a connection. In Wireshark the stream of bits that keep the connection alive are originating from the Android phone so it appears to be a problem on the Android side. We now ensure disconnection from nRF side if this happens.
  • Hi Francois
    Correct me if I am wrong, but does your BtDataTxComplete flag check for the BLE_EVT_TX_COMPLETE event flag? If so, I can see this as normal behavior that your code waits in the while(BtDataTxComplete == 0) {}; loop if you have sent the BLE packet to the softdevice with ble_nus_string_send and have not received a BLE_EVT_TX_COMPLETE from the softdevice, which means that the packet has been sent. Then the packet is just waiting in a softdevice buffer and waiting to be sent. When you connect again with your phone, the packet is sent, which triggers a BLE_EVT_TX_COMPLETE event and the code continues execution.
  • Indeed, it could be the case. We are getting closer to a solution :-)
    However when the connection is "brutal" and a TX is happening, "BLE_GAP_EVT_DISCONNECTED" is never reached... I could put "BtDataTxComplete == 1" there and exit the loop...
    Would "BLE_GAP_EVT_TIMEOUT" happen in case of brutal disconnection?
    See
        case BLE_GAP_EVT_CONNECTED:
            //err_code = bsp_indication_set(BSP_INDICATE_CONNECTED);
            //APP_ERROR_CHECK(err_code);
            LED_On();
            //err_code = bsp_indication_set(BSP_INDICATE_IDLE);
            LED_Off();
            isInPushMode = 0;
            BtCommandWasReceived = COMMAND_EMPTY;
       case BLE_GAP_EVT_TIMEOUT:
    Thanks again!
  • Are you perhaps calling the ble_nus_buffer_send function from an interrupt context? If that is the case, it will block any softdevice callbacks, including the BLE_GAP_EVT_DISCONNECTED. The solution is to execute the ble_nus_buffer_send in main context, which enables any BLE callback to interrupt the wait in the ble_nus_buffer_send function. See the priority scheme here
