PWM problem solved?
I need PWM on 2 pins, with a varying duty cycle, and read some posts in this forum on the subject. I am still using SDK7.2.0, with SD7. Our product is stable, so I do not want to switch to another SDK. However, I can back-port a working solution myself, no problem.
When using the SDK7 version of the PWM example, I also observe the inversions as mentioned here, and also sometimes short periods of a constant level (mostly high).
question: in SDK11, are all problems solved? So is that a good starting point for my back-port exercise? Or should I just forget about PWM completely?
