ble_gap error
I am getting an error on a connection via the ble nus service that is causing me to scratch my head. If I suppress the error the connection seems fine and I don't notice any problems, but I'm concerned I might be creating a problem for myself down the line by ignoring it.
The error manifests itself here:
case BLE_GAP_EVT_CONNECTED:
    //indicate_with_led(SLOW);
The err_code is 0x2000265c. Now I understand this to be a gap error by virtue of the base number but what is 0x265c? I have had a look at some of the various headers for the s132 including ble_gap.h, nrf_error.h and others but I haven't be able to identify it.
Any assistance appreciated.
  • @Richie: You need to provide more code on where you found that, which function, which file name which SDK etc. It doesn't make much sense to check for err_code without assign a value or return code to it.
  • Hi Hung,
    So this is the nRF52 and SDK 11 with SD 132 v 2. This is in main in the function on_ble_evt() I am connecting via the NUS and the connection parameters are according to the example in the SDK. If I comment out the error check, the connection seems fine but as I say I just want to make sure I am not storing up a problem for later.
  • Are you sure you didn't modify the code? in ble_app_uart in main.c I have this:
    static void on_ble_evt(ble_evt_t * p_ble_evt)
        uint32_t                         err_code;
    if you are using the central example ble_app_uart_c, in main.c you should have this:
        APPL_LOG("Connected to target\r\n");
        // start discovery of services. The NUS Client waits for a discovery result
        err_code = ble_db_discovery_start(&m_ble_db_discovery, p_ble_evt->evt.gap_evt.conn_handle);
    If you removed all the API call when the event occurs, you should also remove the APP_ERROR_CHECK(err_code);
  • Ok - the call I was concerned about wasn't being asked to return an err_code hence must be unrelated. That's why I couldn't find it. Thanks Hung.
