Hi there,
I am currently working on a project where I would need to use the Segger J-link needle programmer with 6 pin header. We have produced the board and after following the forums and previous designs we tried to program the device but it would not detect the Cortex M device.
We think that it might have to do with the actual header pins which I might have not connected correctly on the board. Would you please advise on what we should do in order to correct the fault?
Another question is if there are any other connections needed or features enable to program the nRF52 (i.e. set any pins high) in order to ensure correct programming. For the design we did not consider any other pins, but we think the datasheet might say otherwise at another read.
Thank you very much.
