It seems that NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE has wrong documentation. In sdk_config.h it says:
// <o> NRF_LOG_BACKEND_SERIAL_UART_BAUDRATE - Default Baudrate
// <251658240=> 921600 baud
// <268435456=> 57600 baud
But if I measure the speed I see:
251658240 = 957 854 baud
268435456 = 1 008 064 baud
Also even though with 957 854 baud I see often the correct text (with documented speed 921600 I saw always nothing) sometimes it happens that text is corrupted.
Expected and often got text:
APP:INFO:Helo world
SDH:INFO:sd_ble_enable: RAM START at 0x20003000
SDH:WARNING:sd_ble_enable: app_ram_base should be adjusted to 0x20002128
SDH:WARNING:ram size should be adjusted to 0xded8
APP:INFO:Heart Rate Sensor Start!
APP:INFO:Fast Adverstising
Sometimes in ~30% of cases I get corrupted text - for example:
APP:INFO:Helo world
Sa▒:▒*▒▒'.▒%1+ 1▒
▒▒%5%▒!=▒1
▒▒!▒:▒*▒▒'.%▒!=▒1▒
▒▒▒▒▒▒▒▒▒▒▒�▒▒▒▒e▒▒▒'jr▒▒U9▒=▒▒▒%▒▒▒'▒
▒▒▒▒%▒%95
Also interesting is that when I use highest speed rate (268435456 = 1 008 064 baud) I never get garbled text...
So my questions are:
Will you correct documentation?
Why you do use ugly numbers (like
268435456) insdk_config.hcomments if you could use defined macro (likeUART_BAUDRATE_BAUDRATE_Baud1M) from filenrf52_bitfileds.h: ? -
Just out of curiosity - why the mode 251658240 = 957 854 baud does not work sometimes?
