Don't stay in sleep mode after switch off voltage
for our prototyp we use a NRF52. When i flash the device, it will always be go in sleep mode after a duration of time and stay in there.
Is there an interrupt which wake it up?
The workaround from Errata for the Engineering A was also implemented.
Thank for your help.
  • If you lose power, known as brownout, the chip should be held in reset so it does not output spurious signals, and the chip is non-functional. When power comes back, known as POR power on reset, it enters the reset ISR and reboots. Do you expect it to be in sleep mode after such a POR? Your reset ISR must do that.
