BLE not working with timer interrupt (RFduino)
Hi guys,
I am using the RFduino nrf51822 chip. I am using the TIMER2 interrupt and it works fine. But when I try to use the BLE along with the timer interrupt both don't work. I don't get the advertisement for the connection to be made neither does the timer work.
When I stop the timer the Bluetooth works fine and vice versa. I want both the timer and BLE to work together. Here is the code:
#include<RFduinoBLE.h>
  int i = 0;
  uint_fast16_t volatile number_of_ms = 10;
  void timers(void)                    // directly pass the value you want the cycle to be in mS
    NRF_TIMER2->TASKS_STOP = 1;  // Stop timer
    NRF_TIMER2->MODE = TIMER_MODE_MODE_Timer;  // taken from Nordic dev zone
    NRF_TIMER2->BITMODE = TIMER_BITMODE_BITMODE_16Bit;
    NRF_TIMER2->PRESCALER = 9;  // 32us resolution
    NRF_TIMER2->TASKS_CLEAR = 1; // Clear timer
    // With 32 us ticks, we need to multiply by 31.25 to get milliseconds
    NRF_TIMER2->CC[0] = number_of_ms * 31;
    NRF_TIMER2->CC[0] += number_of_ms / 4;
    NRF_TIMER2->INTENSET = TIMER_INTENSET_COMPARE0_Enabled << TIMER_INTENSET_COMPARE0_Pos;
    NRF_TIMER2->SHORTS = (TIMER_SHORTS_COMPARE0_CLEAR_Enabled << TIMER_SHORTS_COMPARE0_CLEAR_Pos);
    attachInterrupt(TIMER2_IRQn, TIMER2_Interrupt);
    NRF_TIMER2->TASKS_START = 1;  // Start TIMER
  void setup() {
    // put your setup code here, to run once:
    RFduinoBLE.advertisementData = "abc";
    RFduinoBLE.deviceName = "abc";
    RFduinoBLE.txPowerLevel = +4;
    RFduinoBLE.begin();
    Serial.begin(9600);
    timers();
  void loop() {
  void TIMER2_Interrupt(void)
    if (NRF_TIMER2->EVENTS_COMPARE[0] != 0)
      Serial.println(i);
      RFduinoBLE.send(i);
      i++;
      NRF_TIMER2->EVENTS_COMPARE[0] = 0;
