nRF51822 over the air bootloader with gcc
For my current project, I need to compile the »over the air bootloader« with gcc (because our buildserver runs on linux, developers using Mac … no Windows and no Keil so far).
But unfortunaly, the bootloader example from the sdk (5.1) examples won't compile with gcc. It's missing gcc makefile and even there are at least 2 Keil specific files in the project (arm_startup_nrf51.s and bootloader_util_arm.c).
Could you provide support to help me on this topic?
I'd also checked:- devzone.nordicsemi.com/index.php/nrf51822-bootloader-with-gcc
  • Dear all,
    I have somewhat strange DFU behaviour, the bootloader starts and advertises, connection is also possible, but as soon as I press "Upload" it fails. I couldnt debug it while in the SoftDevice.
    Tried both ios apps "nRF Loader" and DFU from "nRF Toolbox", also same failer with hex or bin file. With the sniffer I can see some packages sent, the progressbar goes to 1% and then "asserts"/fails.
    Anyone has had similar issue?
    Here is my env: s110_nrf51822_6.0.0_softdevice.hex nrf51_sdk_v5_2_0_39364 is used, on the DevKit nrg6310 board.
    my src zip is attached, I read again and again this thread, seems to have all your comments in. Or am I missing something? DFU_GCC_OL.zip
    image description
    EDIT: make log file attached
  • In your file you have Keil's attribute((at(...))), but you need attribute((section ("..."))). Or maybe you uploaded wrong file in attached project archive?
