S132 v3 Exchange MTU (LE Data Packet Length Extension does't work)
Hi, I encountered some problem using the S132v3.
With the s132 v3 and sdk12, I want to extend the ble transfer size.
Now I can change the att_mtu to 100, and iphone can write more than 20bytes to the characteristic.
But!!! I found that the LL Data PDU is fragmented by 27bytes, so the pdu length is still not extended.
When I dig deeper with the sniffer, I found that nRF52 response the LL_LENGTH_REQ cmd with LL_UNKNOWN_RSP. It should be LL_LENGTH_RSP with a BLE_EVT_DATA_LENGTH_CHANGED event to the app layer.
I also use sd_ble_opt_set(BLE_GAP_OPT_EXT_LEN, &option), but no effect.
There must be something wrong with the S132 or me... I need you help or a S132 bugfix.
image description
After using the examples from Petter Myhre
GATT Client: nRF52 DK GATT Server: nRF52 DK LL_LENGTH_REQ ---- LL_LENGTH_RSP image description
GATT Client: iPhone6 iOS10 GATT Server: nRF52 DK LL_LENGTH_REQ ---- LL_UNKNOWN_RSP image description
Both the LL_LENGTH_REQ packet are the same, but the s132 doesn't response to iphone.
  • @eyeye sniffer traces you've posted show that iPhone 6 doesn't support DLE as it responds LL_UNKNOWN_RSP to nordic's LL_LENGTH_REQ. Note that GATT server/client is a different concept from central/peripheral denoted on sniffer traces master/slave. Most notably GATT server - the nRF is a slave device on sniffer.
    So not a bug in S132, maybe a bug in iPhone if Apple intended to support DLE. Also I've done some reading around and as far as user testimonials go Nexus 5x is the only device I could find confirmation of DLE.
    I also found this article: www.argenox.com/.../ denying iPhone support for DLE.
  • Very appreciate for your reply and patient. now I understand where is my problem, i thought LL_LENGTH_REQ was sent by S132, it's a big mistake. It's really iPhone haven't support DLE, just mtu exchanging. Thank you for all your replies above.
