Bond manager
I try to add to my project the bond functionality based on the glucose demo app. I added ble_bongmngr.c , pstorage.c to my project, initialize it...
When i try to bond from Master Control panel, it disconnect with this message: [17:27:07.0] BondToDevice() [17:27:10.1] Lost connection to device. Reason: BTLE_CONNECTION_TIMEOUT [17:27:10.1] SERVER: Received packet <HciEvent: eventCode=0x0A> - <HciEvent: eventCode=0x0A> [17:27:10.1] SERVER: Received Link Loss [17:27:10.1] Error: No connection
in main.c
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    ble_bondmngr_on_ble_evt(p_ble_evt);
    ble_gls_on_ble_evt(&m_gls, p_ble_evt);
    ble_bas_on_ble_evt(&m_bas, p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
static void bond_manager_init(void)
    uint32_t            err_code;
    ble_bondmngr_init_t bond_init_data;
    bool                bonds_delete;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    // Clear all bonded centrals if the Bonds Delete button is pushed.
   // err_code = app_button_is_pushed(BONDMNGR_DELETE_BUTTON_PIN_NO, &bonds_delete);
    //APP_ERROR_CHECK(err_code);
		bonds_delete = true ;
    // Initialize the Bond Manager.
    bond_init_data.flash_page_num_bond     = FLASH_PAGE_BOND;
    bond_init_data.flash_page_num_sys_attr = FLASH_PAGE_SYS_ATTR;
    bond_init_data.evt_handler             = NULL;
    bond_init_data.error_handler           = bond_manager_error_handler;
    bond_init_data.bonds_delete            = bonds_delete;
    err_code = ble_bondmngr_init(&bond_init_data);
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t                         err_code = NRF_SUCCESS;
    static ble_gap_evt_auth_status_t m_auth_status;
    ble_gap_enc_info_t *             p_enc_info;
        case BLE_GAP_EVT_CONNECTED:
            //nrf_gpio_pin_set(CONNECTED_LED_PIN_NO);
            //nrf_gpio_pin_clear(ADVERTISING_LED_PIN_NO);
            err_code = app_button_enable();
						//nrf_gpio_pin_clear(CONNECTED_LED_PIN_NO);
            // Since we are not in a connection and have not started advertising, store bonds.
            err_code = ble_bondmngr_bonded_centrals_store();
            advertising_start();
            // If the display is not available, do not use MITM.
            m_sec_params.mitm    = 0;
            m_sec_params.io_caps = BLE_GAP_IO_CAPS_NONE;
            err_code = sd_ble_gap_sec_params_reply(m_conn_handle,
                                                   BLE_GAP_SEC_STATUS_SUCCESS,
                                                   &m_sec_params);
            err_code = sd_ble_gatts_sys_attr_set(m_conn_handle, NULL, 0);
        case BLE_GAP_EVT_AUTH_STATUS:
            //m_auth_status = p_ble_evt->evt.gap_evt.params.auth_status;
            //break;
        case BLE_GAP_EVT_SEC_INFO_REQUEST:
            p_enc_info = &m_auth_status.periph_keys.enc_info;
            if (p_enc_info->div == p_ble_evt->evt.gap_evt.params.sec_info_request.div)
                err_code = sd_ble_gap_sec_info_reply(m_conn_handle, p_enc_info, NULL);
                // No keys found for this device
                err_code = sd_ble_gap_sec_info_reply(m_conn_handle, NULL, NULL);
        case BLE_GAP_EVT_TIMEOUT:
            if (p_ble_evt->evt.gap_evt.params.timeout.src == BLE_GAP_TIMEOUT_SRC_ADVERTISEMENT)
                // Go to system-off mode (this function will not return; wakeup will cause a reset)
               // err_code = sd_power_system_off();
				case BLE_GAP_EVT_RSSI_CHANGED:
						//err_code = app_fifo_put(&rssi_fifo, p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
						//if ( err_code == NRF_ERROR_NO_MEM){
							rssi_check(p_ble_evt->evt.gap_evt.params.rssi_changed.rssi);
				case BLE_GATTS_EVT_RW_AUTHORIZE_REQUEST:
            uint8_t test_buffer[20];
            ble_gatts_rw_authorize_reply_params_t reply;
            memset(&reply, 0, sizeof(ble_gatts_rw_authorize_reply_params_t));
            reply.type = BLE_GATTS_AUTHORIZE_TYPE_WRITE;
            for(uint8_t i = 0 ; i < p_ble_evt->evt.gatts_evt.params.authorize_request.request.write.len; i++)
                test_buffer[i] = p_ble_evt->evt.gatts_evt.params.authorize_request.request.write.data[i];
            // This is a test function. Master will get this error when first byte is not 0x12.
            if (test_buffer[0] != 0x12)
                reply.params.write.gatt_status = BLE_GATT_STATUS_ATTERR_WRITE_NOT_PERMITTED;
            err_code = sd_ble_gatts_rw_authorize_reply(p_ble_evt->evt.gap_evt.conn_handle, &reply);
Did I forget something?
