nrf52 recieves wrong SPI memory flash ID
I'm working with the PCA10040, the SDK V11.0.0. and the winbond memory flash W25Q80BV.
For the SPI connection I'm using the the SPI2 because TWI0 and TWI1 are being used by other sensors.
I have a problem when I try to get the memory flash ID information (through order 0x90): It should send (0x00,0x00,0x00,0x00,0xEF,0x13) but instead it sends random values in bytes 5 and 6. I've checked the pin connection of SCK,MISO,MOSI and SS and it's correct. Also I've checked that /HOLD pin is high. I've tried with the 0 and 3 spi modes (as the winbond datasheet indicates) and also different frequencies values, but still I couldn't get the proper value.
Here I attach the code delevoped based on the spi example:
#if defined(BOARD_PCA10036) || defined(BOARD_PCA10040)
#define SPI_CS_PIN   29 /**< SPI CS Pin.*/
#elif defined(BOARD_PCA10028)
#define SPI_CS_PIN   4  /**< SPI CS Pin.*/
#else
#error "Example is not supported on that board."
#define SPI_INSTANCE  2 /**< SPI instance index. */
static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
static uint8_t       m_tx_buf= 0x90;           /**< TX buffer. */
static uint8_t       m_rx_buf[6];    /**< RX buffer. */
 * @brief SPI user event handler.
 * @param event
void spi_event_handler(nrf_drv_spi_evt_t const * p_event)
    spi_xfer_done = true;
    NRF_LOG_PRINTF(" Transfer completed.\r\n");
    LEDS_CONFIGURE(BSP_LED_0_MASK);
    LEDS_OFF(BSP_LED_0_MASK);
    APP_ERROR_CHECK(NRF_LOG_INIT());
    NRF_LOG_PRINTF("SPI example\r\n");
    nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG(SPI_INSTANCE);
		spi_config.mode= NRF_DRV_SPI_MODE_0;
    spi_config.ss_pin = SPI_CS_PIN;
		spi_config.frequency= NRF_DRV_SPI_FREQ_1M;
		spi_config.bit_order=NRF_DRV_SPI_BIT_ORDER_MSB_FIRST ;
    APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
    while(1)
        // Reset rx buffer and transfer done flag
        memset(m_rx_buf, 0, sizeof(m_rx_buf));
        spi_xfer_done   = false;
        APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &m_tx_buf,sizeof(m_tx_buf) , m_rx_buf, sizeof(m_rx_buf)));
        while(spi_xfer_done == false)
            __SEV();
            __WFE();
            __WFE();
						for(int i=0;i<6;i++){
							NRF_LOG_PRINTF(" Received: %04x\r\n",m_rx_buf[i]);
Here I attach the RTT information send and the signals values obtained by a logic analyzer.
image description
image description
I've tested the memory chip with an arduino application and it's working fine so the problem must be in some configuration parameter of the nordic side.
Somebody has experience a similar issue or have any idea about what I'm doing wrong?
  • I just suggested one of the possible problems. It can be capacitance of the line or ringing. I will let Nordic to comment on differences between nRF51 and nRF52, I'm not using 52 yet.
  • I also ask myself about this. I just give you what I think about it. I have requested the help from a nordic engineer. I will get you in touch
  • Hi!
    I've been having a similar problem. I'm trying to test the flash memory (Winbond W25X40CL) on my custom board, but when I read the ID, I only get 0xFF as response.
    Here's a sample of my code:
    static void peripheral_init(void) {
        if(!nrf_drv_gpiote_is_init()) {
            APP_ERROR_CHECK(nrf_drv_gpiote_init());
        nrf_drv_spi_config_t config = {0};
        config.sck_pin = BOARD_SCK;
        config.mosi_pin = BOARD_MOSI;
        config.miso_pin = BOARD_MISO;
        config.ss_pin = BOARD_FLASH_CS;
        config.irq_priority = APP_IRQ_PRIORITY_LOW;
        config.frequency = NRF_DRV_SPI_FREQ_250K;
        config.mode      = NRF_DRV_SPI_MODE_0;
        config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
        NRF_GPIO->PIN_CNF[BOARD_SCK] = 0x00000301;
        APP_ERROR_CHECK(nrf_drv_spi_init(&m_spi_master, &config, NULL));
        SEGGER_RTT_printf(0, "SPI Init OK! \n");
    Then in the main I do:
    uint8_t tx_buffer [] = {0x90, 0x00, 0x00, 0x00};
    uint8_t rx_buffer[6] = {0};
    uint8_t length = sizeof(tx_buffer);
    if(nrf_drv_spi_transfer(&m_spi_master, tx_buffer, length, rx_buffer, 6) == NRF_SUCCESS) {
        SEGGER_RTT_printf(0, "Transfer Success! \n");
        for (uint8_t i = 0; i < 5; i++) {
            SEGGER_RTT_printf(0, "0x%02x \n", rx_buffer[i]);
    As you can see, I've tried adding the NRF_GPIO->PIN_CNF[BOARD_SCK] = 0x00000301 and still nothing. I've also tried different combinations of frequencies and modes, without success.
    Do you know if there's still a problem regarding the CLK pin? It might be a hardware problem (haven't check yet) but I saw this
  • Hello the problem is because spi is working in full duplex mode normally. It means that you can receive data while you are transmitting. For your case you are receiving data after transmitting the request. Therefore you have to read more bytes (tx_data_length+rx_data_length) to have the manufacturer id.
    if(full_duplex)
        // start the transaction
        err_code = nrf_drv_spi_transfer(_spi, tx_data, tx_data_length, rx_data, rx_data_length);
       err_code = nrf_drv_spi_transfer(_spi, tx_data, tx_data_length, rx_data, tx_data_length + rx_data_length);
  • I tried this solution but I it is not working for me for some reason.
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static uint8_t       m_tx_buf[4];           /**< TX buffer. */
    static uint8_t       m_rx_buf[10];    /**< RX buffer. */
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event,
                           void *                    p_context)
        NRF_LOG_INFO("Transfer completed.");
        if (m_rx_buf[0] != 0)
            NRF_LOG_INFO(" Received:");
            NRF_LOG_HEXDUMP_INFO(m_rx_buf, strlen((const char *)m_rx_buf));
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = SPI_SS_PIN;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        NRF_GPIO->PIN_CNF[SPI_SCK_PIN] = 0x00000301;
        spi_config.sck_pin  = SPI_SCK_PIN;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
        NRF_LOG_INFO("SPI example started.");
        while (1)
            m_tx_buf[0] = 0x90;
            APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, m_tx_buf, 4, m_rx_buf, 10));
            while (!spi_xfer_done)
                __WFE();
            NRF_LOG_FLUSH();
            bsp_board_led_invert(BSP_BOARD_LED_0);
            nrf_delay_ms(200);
