HardFault error when writing to characteristic in uart interrupt
Hello everyone,
When i get message from uart, i need to update my custom service's characteristic. I tried the code in the below, sd_ble_gatts_value_set function gives me HardFault error.
Am I doing something wrong to add characteristic? how should I do?
S130, SDK11
Code: uart_event_handle function
        case APP_UART_DATA_READY:
		if(index == 5) {
			if(data_array[0] == '$') {
				value.len = 5;
				value.offset = 0;
				uint8_t data[5];
				for(int i = 0; i < 5; i++) {
					data[i] = data_array[index + i];
				value.p_value = data;
				if(m_connected) {
					err_code = sd_ble_gatts_value_set(m_kcomms.conn_handle, m_kcomms.product_char_handles.value_handle, &value);
			index = -1;
		index++;
Characteristic code:
I changed to SET_OPEN from NO_ACCESS , vlen = 1 and to USER from STACK but nothing changed.
    ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_md_t attr_md;
    ble_gatts_attr_t    attr_char_value;
ble_uuid_t ble_uuid;
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.write_perm);
cccd_md.vloc = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read   = 1;
char_md.char_props.write  = 1;
char_md.p_char_user_desc  = NULL;
char_md.p_char_pf         = NULL;
char_md.p_user_desc_md    = NULL;
char_md.p_cccd_md         = &cccd_md;
char_md.p_sccd_md         = NULL;
memset(&attr_char_value, 0, sizeof(attr_char_value));
ble_uuid128_t base_uuid = {0x11, 0xFE, 0xD4, 0x94, 0xEA, 0xFE, 0xEC, 0x82, 0x20, 0x4B, 0x6E, 0x65, 0x1A, 0xC1, 0xCD, 0x9F};
uint32_t err_code;
err_code = sd_ble_uuid_vs_add(&base_uuid, &p_kcomms->uuid_type);
ble_uuid.type = p_kcomms->uuid_type;
ble_uuid.uuid = 0xC11A;
memset(&attr_md, 0, sizeof(attr_md));
BLE_GAP_CONN_SEC_MODE_SET_OPEN(&attr_md.read_perm);
BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
attr_md.vloc       = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth    = 0;
attr_md.wr_auth    = 0;
attr_md.vlen       = 0;
attr_char_value.p_uuid       = &ble_uuid;
attr_char_value.p_attr_md    = &attr_md;
attr_char_value.init_len     = 0;
attr_char_value.init_offs    = 0;
attr_char_value.max_len      = MAX_CHARACTERISTIC_VALUE;
attr_char_value.p_value     = NULL;
return sd_ble_gatts_characteristic_add(p_kcomms->service_handle, &char_md,
                                           &attr_char_value,
                                           &p_kcomms->stock_info_char_handles);
  • I found the solution but i want to know if there is more proper way.
    If i receive the right message from uart, i set a variable to 1. Then i am checking for that variable is set on for loop in main function. If set, i am writing to characteristic via sd_ble_gatts_value_set
  • Sending an SV instruction from an higher interrupt priority context than the SV call ('2') itself will lead to a hardfault exception. Setting the interrupt priority to 'APP LOW' in the initialization of the UART should fix this problem. Calling the sd_ble_gatts_value_set() function in main context as you described will also work.
  • Thank you this way is better :)
