DFU update with encrypted bin file
We are currently using SDK 10 experimental boot loader example. We would like to encrypt the firmware before creating the zip file for OTA. The procedure we followed is that we replace the original bin file with an encrypted bin file in OTA package. But when we use this package the nordic app(android) does not allow update.
I am wondering if the SHA is verified by the app also before starting OTA, since the SHA is calculated on original bin file. The reason we would like to do this way is that we decrypt firmware stream as soon as it is received and then stored in flash pages. Hence we would like to have SHA of original bin file in the init packet.
Could you suggest what we can do instead in order for app to send encrypted bin file.
FYI: The app says the following "[DFU] Opening file failed: The zip file must contain an Application, a Softdevice and/or a Bootloader"
Here is the example zip file. I can update this package by selecting .bin and .dat file manually. But if i chose zip file it throws error as described above.
Thanks in Advance, Arjun
