nRF51 Refuses Connection Parameter Negotiation
I have an nRF51 project using SD110 and SDK8.0 that refuses connection parameter negotiation. I a handler that would disconnect bluetooth when a connection parameter negotiation fails and it would disconnect every time it connects to something. Changing the values of the connection parameter makes no difference, likewise with changing the connection parameter negotiation interval and number of attempt. Any help on this case?
Thank you
Edit: I've found what seemed to be the issue. I had called conn_params_init and sec_params_init before calling gap_params_init. Once I rearranged them so that gap_params is initialised befor conn_params and sec_params, the issue is gone, connection parameter negotiation is succesfull and the nRF51 would maintain connection.
  • Did you also call conn_params_init() before calling services_init()? If that is the case then I think the note below from the SDK v8.0.0 documentation of ble_conn_params_init() explains the behaviour
    If the negotiation procedure should be triggered when notification/indication of any characteristic is enabled by the peer, then this function must be called after having initialized the services.
    -Bjørn
