I use the BDS v1.1 and nRF Plugin 1.2.2 (from 23.Dec.15). My goal is to simply generate a code for the cycling power profile defined by the Bluetooth SIG. I dont change anyithing. I simply drag and drop the CPP in the designer tab in BDS and go to Tools->Generate Code (using nRF Pluginv1.2.2.). During the building process the following message appears:
the log says:
The code generation works for other profiles, such as the Heart Rate profile. And it also works, if I just add the Cycling Power Measurement characteristic to a random profile. But it does not work for the Cycling Power Service.
Is there an incompatibility with the nRF Plugin, since the CPP was released in March 2016 (after the release of the Plugin).
Thank you for your help.
