I made an application inspired from the ble_uart example project.
I encounter now a problem that I don't have with the ble_uart example.
I found that after few minutes, the connection is lost with nRF Connect (Android). Using a debugger, I see that the disconnection comes from a BLE_CONN_PARAMS_EVT_FAILED event that leads in a call to sd_ble_gap_disconnect().
Now I want to understand the reason why I get this BLE_CONN_PARAMS_EVT_FAILED event. Using a sniffer, I can see that there are 3 connection parameter update requests from the nRF52 that are rejected by the smartphone respectively 5s, 35s and 65s after connection establishment. 95s after connection establishment, the connection is lost.
Attached you can see what I use in the firmware as acceptable connection interval, I also show the content of the parameter update request from the nRF52 to the Smartphone.
Question 1: what would cause the nRF52 to request for connection parameters update? I don't see this request with the sniffer whant I run the ble_uart example, only with my application.
Question 2: do you think that the smartphone rejects the update request because of these strange values 0xFFFF for both minimum and maximum?
Question 3: what would cause the connection parameter request to include these strange values 0xFFFF for both minimum and maximum?
SDK 11. S132 nRF52832 Keil
