I use nRF51 dk with SDK_12.0 and soft device S130.
Here i put my screenshot:
If you want to use logging over RTT, you can use the SDK logging functionality directly. Open the sdk_config.h file that comes with the project, and open the configuration wizard tab at the bottom of the file. Enable logging over RTT by checking the RTT box. When logging over RTT is enabled, the log functions can be used normally, like NRF_LOG_INFO("Heart Rate Sensor Start!\r\n") for instance.
I can't see configuration wizard in my keil. Do I need to install something? or is there any option to enable it?
When you open sdk_config.h there is no "configuration wizard" at the bottom of the text editor window?
Which version of Keil do you use?
IDE-Version: µVision V5.21.1.0 Copyright (C) 2016 ARM Ltd and ARM Germany GmbH. All rights reserved. License Information: Vishnu P I am using SDK11 and hence no sdk_config.h but nrf_drv_config. I am not seeing anything at the bottom of the text window. thanks
The configuration wizard was introduced in SDK 12.
