MY BLE connection lost during run time!
I mounted the chip onto my own PCB, I am not using a devkit, My board is "Wireless-Tag WT51822-S2", it is a module that uses nRF51822-QFAA as (SoC)
I am the ble_app_uart example inside sdkv10.0.0 as a framework to my application.
My application is simply a smart-remote which contains two interrupts: 1- TIMER1 interrupt (I am using it as a scheduler to run a background code inside the main function). 2- GPIOTE Interrupt that fires when an input pin toggles.
The input pin is sensing the IR receiver sensor and generates an interrupts with each edge, Inside the interrupt I calculate the time between edges.
I load these times into an array, run my algorithm, pack my ble payload, then send the frame to my smart phone.
So when I push any button on my remote-control I am expecting to get a message nRF Toolbox.
But in reality I get a correct responses each push button, and after some trials/time (random) I get my connection lost!!
I don't know exactely why it loses the connection, could anyone help please ? :)
  • Thank you Petter for your reply. I will try to get the event but anyway when I go home. But anyway software goes to HardFault handler then the connection stopped
