I have some trouble to use the Secure Bootloader example, which comes with the nRF5_SDK_12.1.0
I installed the latest nrfutil and hexmerge. I can compile the bootloader (use Debug mode). Then I merged the hex file with the S132 Softdevice hex file. So far no problem.
But doesn't matters, if i use my self compiled bootloader or the bootloader image which comes with the SDK, the upload always failed with my own Application package (zip). When I use the example App, it worked in always.
CRC Failure
Here the way I made all the stuff:
Compile the bootloader
Creating the Bootlaoder settings hex
Uses Blinky from the examples to create a application.zip - Signing the file / Key is generated with nrfutil
Compare the self made "Zip-Files" with the Example
With the example the upload is successfull
So what is the Problem with the CRC? I read the other thread, but this is not the same SDK Version there. It's different to the 12.1.0 with the secure bootloader.
Hope, you can give me some clues.
Regards, Andre
