My project name is Remote Operated Vehicle. Basically i am using a PS2 controller as the joystick to control the car. So, my aim is to build wireless interface between two microcontroller using nRF24L01. One microcontroller acts as a Tx, and the other one as a Rx. I have already run the code on both microcontroller. But i dont know how to check if there is a successful communication between these two microcontroller. Please help me how do i test this communication? How to check if the Rx gets the message from the Tx? Any help is much appreciated. Thank you!
Here is the nRF24L01.. the marking is: NRF A 24L01+ 083DAE Tx code:
- Project Name: NRF24L01 demonstration code, Transmitter
- Company: (c) mikroElektronika, 2011
- Revision History:
20111104 (ZR):
- initial release;
- Description:
This code demonstrates how to use NRF 24L01+ to send and receive data over RF channel.
It is expected that Rx is setup in such way that it returns ACK as well as 20 bytes of response message (ACK Payload).
- Test configuration:
MCU: P18F45K22
Dev.Board: EasyPIC7
www.mikroe.com/.../
Modules: NRF24L01+, http://www.nordicsemi.com/
ac:NRF24L01P
Oscillator: 8MHz
SW: mikroC PRO for PIC
www.mikroe.com/.../
- NOTES:
Both MCU and NRF24L01+ must be powered by 3.3V relative to GND
sbit Irq_pin at PORTB.B0; sfr; sbit Mosi_pin at LATC.B7; sfr; sbit Ce_pin at LATA.B4; sfr; sbit Sclk_pin at LATA.B3; sfr; sbit Csn_pin at LATA.B2; sfr; sbit Miso_pin at PORTC.B6; sfr;
sbit Irq_tris at TRISB.B0; sfr; sbit Mosi_tris at TRISC.B7; sfr; sbit Ce_tris at TRISA.B4; sfr; sbit Sclk_tris at TRISA.B3; sfr; sbit Csn_tris at TRISA.B2; sfr; sbit Miso_tris at TRISC.B6; sfr;
char Code_[32]; // addressing code (see datasheet for NRF24L01+) char Outgoing[25]; // outgoing packet char Incoming[25]; // incoming packet
void Init() { ANSELA = 0; ANSELB = 0; ANSELC = 0; ANSELD = 0; LATD = 1; TRISD = 0;
INTCON = 0; // disable all interrupts
// address code Code_[10] = 0xAA; // choose bytes at your wish Code_[11] = 0xAA; Code_[12] = 0xAA; Code_[13] = 0xAA; Code_[14] = 0xAA;
NRF24L01P_RF_Channel = 20; // Radio frequency channel, in range 0..124 NRF24L01P_Init(5); // initialize NRF24L01+ NRF24L01P_Setup_Tx(Code_); }
void MakeMessage() { // form outgoing message char i; for (i = 0; i < 20; i++) { OutGoing[i] = i; } }
char DoRF() { char i; char result;
MakeMessage(); result = 0; // no receiver in range while (result != 255) { // keep trying until receiver gets the message memset(&incoming, 33, 20); // prepare incoming i = NRF24L01P_Send(OutGoing, Incoming); // Call receiver Delay_100ms(); LATD++; // indicate that Tx is in progress if (i == 0) { // Rx has received the message and returned the answer, which is in the "Incoming" array LATD = 0; // process Incoming array to extract the message from Rx result = 255; // All is OK, the receiver has got the message } else { // Rx did not receive the message } } }
void Main() { Init; while (1) // keep on transmitting DoRF(); }
Rx code:
- Project Name: NRF24L01 demonstration code, Receiver
- Revision History:
20111104 (ZR):
- initial release;
- Description:
The reciver is setup in such way that it returns ACK as well as 20 bytes of response message (ACK Payload).
MCU: P18F45K22
Dev.Board: EasyPIC7
www.mikroe.com/.../
ac:nrf24L01p
Oscillator: 8MHz
SW: mikroC for PIC
www.mikroe.com/.../
- NOTES:
char InData[25]; // incoming data from RF char testRcv; char PayLoadBuff[25]; char Code_[32];
void interrupt() { // in case you use interrupts, here is the moment when Rx has got the data from Tx
//**************** Rx interrupt ******************* if (INTCON.INT0IF == 1) { INTCON.INT0IF = 0; // clear interrupt flag on RB0 (IRQ pin) } //************************************************* }
void PreparePayload() { char i; // prepare payload to be sent together with the ACK (see datasheet for NRF24L01+) for (i = 0; i < 20; i++) PayLoadBuff[i] = i; NRF24L01P_Write_Ack_Payload(PayLoadBuff, 0); // store payload to transmit buffer }
void Init() { ANSELA = 0; // all pins digital ANSELB = 0; ANSELC = 0; ANSELD = 0;
LATD = 1; TRISD = 0; // we will use PORTD for indicators
INTCON = 0; // no interrupts
INTCON.INT0IE = 1; // allow interrupt on INTO (IRQ_PIN) INTCON2.INTEDG0 = 0; // falling edge on INT0 causes the interrupt
RBPU_bit = 0; // enable weak pull up on PORTB
memset(&InData, 0, 21);// clear the array
Code_[10] = 0xAA; // address code, must be the same on Rx and Tx side Code_[11] = 0xAA; Code_[12] = 0xAA; Code_[13] = 0xAA; Code_[14] = 0xAA;
INTCON.GIE = 1; // enable all interrupts, if you want them }
char DetectTx() { char passcnt; char result;
passcnt = 0; result = 0; NRF24L01P_PowerUp(); // start the NRF chip NRF24L01P_Rf_Channel = 20; // set the radio channel, from 0..124 NRF24L01P_init(5); // initialize RF module with the highest power NRF24L01P_Setup_Receiver(Code_); // configure receiver memset(&InData, 0, 21); testRcv = NRF24L01P_Receive(InData); // procitaj ako je ista je stiglo na RF- brisi buffer PreparePayload(); NRF24L01P_ClearIRQ();
while (1) { passcnt = 0; // try 50 times before giving up while (passcnt < 50) { if (NRF24L01P_Has_Data()) { // is there any data received? testRcv = NRF24L01P_Receive(InData); // read the data and clear Rx buffer PreparePayload(); // prepare payload for the next session passcnt = 0; LATD ++ ; // show activity when data arrives result = 1; } passcnt++; Delay_100ms(); }
NRF24L01P_PowerDown(); // shut down NRF24L01+
Delay_100ms();
NRF24L01P_Rf_Channel = 20; // working channel
NRF24L01P_Init(5); // Initialize RF module
NRF24L01P_Setup_Receiver(Code_); // Reinitialize receiver
memset(&InData, 0, 21); // Clear inoming buffer
LATD.B7 = PORTD.B7 ^ 1;
if (testRcv)
// the data has been received
result = 1;
void main() { Init();
while (1) { if (DetectTx()) { // Tx is here, the data is received, it is stored in InData memset(&InData, 0, 21); // clear indata } } }
I donwloaded the code from libstock.
