3 time aligned PWM channels
I need 3 time aligned PWM channels (period of all three channels needs to start at the same time) at about 100 Hz with 16 bit resolution on the duty cycle. I also need to trigger some code to run when all three channels are in there off cycle.
What is the best way to do this?
I tried the low power PWM lib, but it seems due to the RTC1 timer frequency, this can only support 8 bit resolution at 100 Hz.
I think I need something like the PWM library, but with 3 channels on one timer. What's the reason this is currently limited to 2 channels? Could it be extended to 3 channels?
What about the PWM hardware driver? Does this have the same limitation?
