Following along after my nrfjprog mini-tool for OS X, I've just released a plugin for Eclipse which exposes a template for setting up projects with the right settings for Eclipse native building (i.e. no Makefile).
My plugin builds on the GNU ARM Eclipse plugin which improves Eclipse support for the GNU ARM toolchain immeasurably. That plugin comes with some templates for other boards, mine adds the nrf51822 templates. You can make a template for the 256kB or 128kB devices, with or without softdevice and you get a simple blinky project which you can then edit as you like.
The plugin requires that you have some version of the nrf51 SDK on your machine and you specify the location when you create the project. This was necessary so as not to include Nordic files and also not be tied to one SDK.
The project is at sourceforge.net/.../, the installation instructions are on the Wiki.
I believe the generated project settings give the same compilation steps and flags as the gcc Makefiles and the samples work on my devices. If someone finds discrepancies please tell me and I'll improve it.
