Application crashing at softdevice_enable
I'm trying to implement an application where one board updates another board with Nordic's DFU service. I'm using the NUS client example as a basis to develop the BLE central application.
My main function looks like this:
    SEGGER_RTT_WriteString(0,"Starting DFU application\n");
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, NULL);
    buttons_leds_init();
    db_discovery_init();
    ble_stack_init();
    //ble_services_init();
    nus_c_init();
    // Start scanning for peripherals and initiate connection
    // with devices that advertise NUS UUID.
    scan_start();
    SEGGER_RTT_WriteString(0,"Entering main loop\n");
    for (;;)
        power_manage();
As soon as I uncomment ble_services_init(), the application crashes at softdevice_enable and resets. The error code doesn't even get printed. (see below, after checkpoint 3)
    uint32_t err_code;
    SEGGER_RTT_WriteString(0,"Initializing the SoftDevice and BLE event interrupt\n");
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    SEGGER_RTT_WriteString(0,"Checkpoint 1\n");
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    SEGGER_RTT_WriteString(0,"Checkpoint 2\n");
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    SEGGER_RTT_WriteString(0,"Checkpoint 3\n");
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    SEGGER_RTT_printf(0,"Error code: %d\n", err_code);
    SEGGER_RTT_WriteString(0,"Checkpoint 4\n");
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    SEGGER_RTT_WriteString(0,"Checkpoint 5\n");
Any idea what the problem might be? I'm thinking maybe I need to change some RAM configurations but I'm not sure how.
I'm using SoftDevice s130, SDK11, on nRF51822_qfac. Thanks in advance for your help!
  • I think what was happening is what you explained, that the RTT didn't have a chance to send the data, that's why I thought that the problem was at softdevice_enable(). I debugged using some for(;;)loops to stop execution and I found out that the real problem was at the initialization of the new service. (I'm using GCC, so I didn't have breakpoints like in Keil).
