NRF Dongle Protocol
Hi
I need to develop PC software to Discover, Connect, Get and Set data to the nrf device that we developed.
I am using the MCP and nrf connect but my client want to have his own app.
Where can I get the communication protocol for the dongle or the firmware source code . In other words in the MCP if you click on the discover button what command is being send to the dongle over uart to go into discover mode.
regards
    MCP is based on the Master Emulator, and the DLL file for Master Emulator can be found in C:\Program Files (x86)\Nordic Semiconductor\Master Emulator folder, if you have MCP installed. This can be used to implement your own C# program, but as MCP have been replaced by nRF Connect, I would not recommend that you use this anymore.
    Instead, I would recommend you to check out the pc-ble-driver library source on Nordic's GitHub. This library "provides serial port communication (using SoftDevice API serialization) to an nRF5x IC running the connectivity firmware included". It has bindings for Python and JavaScript, making it suitable for easy application development. Unfortunately, the driver is not well documented yet, but some examples for both Python and Javascript bindings are provided.
    Jørgen
  • S310 is not supported and it should not work with the nRF51822. It will also consume more flash and RAM than BLE-only softdevice. nRF51422 is more expensive due to the licence fee to ANT, and you might also get in trouble with licenses if you use the ANT softdevice on a device not supporting ANT. You should definitely use S130 with nRF51822 devices. BLE beacon app (provided by Nordic) should not use any ANT parts.
