With the same file id and record id, do these two functions do the same thing?
Thanks
Paul
Thanks
Paul
No, as described in the FDS Library documentation, it is possible to have multiple records with the same FILE_ID and RECORD_ID. If you call fds_record_write(), it will only create a new record, meaning you will have two record with the same RECORD_ID. fds_record_update() on the other hand, will create a new record and then invalidate the old record, leaving you with only one record.
When calling fds_record_update(), the parameter p_desc must point to the old record to be invalidated. On return, p_desc will point to the new record, similar to the return of fds_record_write().
Jørgen
