dfu bootloader Loaded Application runs once then doesn't run at the restart.
Hi everyone! I flashed an application with the help of DFU bootloader. The application runs for the first time . The application contains a service that lets the application reset to the bootloader. Then the bootloader wouldn't run the application after doing a power off -> on. Its the dfu bootloader again and the application wouldnt run. What could be causing this? Some info: The application uses a softdevice and has a bluetooth service. I have a similiar application that would run correctly with the same bootloader even after the restart. The µc is nrf52832. I am using iar workbench.
