NRF24L01+ without CRC
Has anyone using nRF24L01 raw (CRC turned off) mode. I try to turn off the CRC (the data sheet offers this option), then I start to miss packets. Once I turn on the CRC, I got every packets I sent.
I assume once I turned off the CRC, I should still get every packet I sent (maybe with error). The loss of packet is consistent and in a regular pattern (every other one).
Is this a known problem or my configuration is wrong (from CRC off to CRC on - only need to change one bit in the config reg).
  • Not sure why you don't want to use CRC. But did you make sure you also set EN_AA = 0x00 and ARC = 0 to disable Enhanced ShockBurst?
