nRF51822 not detected by nRF Connect
I'm trying to program a nRF51822 board following this tutorial (chisight.wordpress.com/.../) using OpenOCD in a Raspberry PI.
I have been able to burn the compilated ble_app_proximity example code (in .hex format) that the SDK contains, and in that case the nRF51822 is detected correctly by the nRF Connect iOS app. However, if I compile the main.c code contained in the same example of the SDK with Segger Embedded Studio, and I burn the .hex output in the same way that I did before, the burn is successful, but nothing is detected by the nRF Connect iOS app.
I'm using the following section placement macros:
FLASH_START=0x1C000 FLASH_SIZE=0x24000 SRAM_START=0x20000000 SRAM_SIZE=0x1800
Thanks in advance !
