nRF51822 Bootloader with GCC - Code for starting the Application
While trying to get the SDK's bootloader working with gcc, I have to replace some ARMCC-speific code found in bootloader_util_arm.c:
__asm void StartApplication(uint32_t start_addr)
    ; Get App MSP.
    LDR   R2, [R0]
    ; Set the main stack pointer to the applications MSP.
    MSR   MSP, R2
    ; Get application reset vector address.
    LDR   R3, [R0, #0x00000004]
    ; No return - stack code is now activated only
    ; through SVC and plain interrupts.
    BX    R3
    ALIGN
void bootloader_util_app_start(uint32_t start_addr)
    StartApplication(start_addr);
After trying some approaches I found 2 apparently working solutions to substitute that for gcc. The 1st one is based on some code I found in Ole Mortens early bootloader implementation:
typedef void (*main_t)();
    main_t app_main =*(main_t*)(start_addr+4);
    app_main();
The 2nd solution uses inline assembler:
    // Assign app code address
    asm volatile(" LDR   R0, =0x14000          \n\t"
    // Get App MSP
                 " LDR   R2, [R0]              \n\t"
    // Set the main stack pointer to the applications MSP
                 " MSR   MSP, R2               \n\t"
    // Get application reset vector address
                 " LDR   R3, [R0, #0x00000004] \n\t"
    // No return - stack code is now activated only
    // through SVC and plain interrupts
                 " BX    R3                    \n\t"
                 " .ALIGN                    ");
Both solutions are working (on my desktop) but are they safe? Don't know if MSP is set right in the 1st approach.
All tested with gcc-arm-none-eabi-4_7-2013q3 and gcc-arm-none-eabi-4_8-2013q4 compiled on a linux host (kubuntu 12.04 with backports) using both Ole Mortons pure-gcc and also the original sdk gcc setup (makefiles, linkerscripts and startup code).
