Generating and using secure DFU keys under Linux
Hi
I'm wondering if anyone have had any success or problems with generating and using secure DFU keys under Linux?
I'm using the latest nrfutil from: github.com/.../pc-nrfutil
SHA1: e5303b994611b1122116ebd07c2185d5a0645d1d
And I'm running Debian (unstable)
[EDIT] I initially forgot to mention the SDK and SD versions and some other things
I'm using s132_nrf52_3.0.0_softdevice.hex from nRF5_SDK_12.1.0_0d23e2a
And the code is running on a custom board containing a nRF52832-QFAA (B0)
[End EDIT]
I generate the private key using:
nrfutil keys generate test.pem
I generate the pubilc key using:
nrfutil keys display --key pk --format code test.pem --out_file src/bootloader/keys/test_key.c
I build the zip archive using:
 nrfutil pkg generate   --application /tmp/app.hex --key-file test.pem --sd-req 0x8C --hw-version 52 --application-version 0 /tmp/g3_test.zip
I can verify / dump the content of the public key inside dfu_req_handling.c by calling:
NRF_LOG_HEXDUMP_INFO(crypto_key_pk.p_le_data, crypto_key_pk.len);
Proving that the key has successfully been used and linked into the .hex file
However the DFU upload using nRF Connect on my Android phone fails on the line:
err_code = nrf_crypto_verify(NRF_CRYPTO_CURVE_SECP256R1, &crypto_key_pk, &hash_data, &crypto_sig);
The error code returned is:
NRF_ERROR_INVALID_DATA If the signature did not match the provided hash or digest.
If I bypass the signature check by not returning NRF_DFU_RES_CODE_INVALID_OBJECT the DFU update completes without any further errors or problems.
Any feedback will be appreciated.
