nRF51822 J-link Suppy Voltage too low. But firmware is running and connectable BLE
I am having trouble in downloading firmware to my development kit. Previously, everything worked and the module already flashed with my BLE firmware. Today, as usual I power up the device and everything works well (detectable and connectable with my smartphone) but when I trying to download the firmware, the error prompted. It senses 0.0V instead of the normal voltage.
Normally this is caused by the power supply to the development board but my case seems to be different. I measure VTG pin on the board, it gives me 0V. I have tried to use another module (development kit came with 2 modules) the problem is the same. I also checked the downloader cable connectivity which is fine too. I wonder what reason causes this issue. J-link problem?
Hopefully someone can guide me out of this. Thank you very much in advanced
  • Hi Kristin and Ole Morten,
    Thanks both of you for the assistance. I have solved the problem by routing the 3.3V from my supply directly to the VTG (pin 1 of the P3 connector). However, I felt it weird because if this is the real problem it should happened when i first program my development kit. I am using the same custom made board to power up the kit.
    Still, many thanks to both of you. Have a nice day.
