Can't flash debug bootloader from SDK 12.1.0. ERROR: The area to write is not erased.
Hi.
I have a BLE peripheral app for the nRF51822. I'm using SDK 12.1.0 with SD 130 v2.0.1 and gcc. I'm implementing DFU OTA at the moment and I notice there are two builds of the example bootloader_secure app for each board, eg. one called pca10028 and another called pca10028_debug. The debug one includes logging statements and so on, so we can use it to debug a bootloader that's not working, I presume. I've managed to get the size of my application down to the point where I have room for it along with the debug bootloader.
To flash my board, I use separate calls to nrfproj, one for each hex file, in my Makefile, like this:
flash: all
	$(NRFPROJ) --eraseall
	$(NRFPROJ) --program $(SOFTDEVICE)
	$(NRFPROJ) --program bootloader/biketracker_debug/armgcc/_build/bootloader_s130.hex
	$(NRFPROJ) --program $(HEX)
	$(NRFPROJ) --reset
I can flash my application along with the NON debug bootloader, but not with the debug one.
eliot-macbook-pro:biketracker-firmware Eliot$ make flash
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --eraseall
Erasing code and UICR flash areas.
Applying system reset.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program /Users/Eliot/dev/nRF5_SDK_12.1.0_0d23e2a/components/softdevice/s130/hex/s130_nrf51_2.0.1_softdevice.hex
Parsing hex file.
Reading flash area to program to guarantee it is erased.
Checking that the area to write is not protected.
Programing device.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program bootloader/biketracker_debug/armgcc/_build/bootloader_s130.hex
Parsing hex file.
Programing device.
/Users/Eliot/dev/nRF5x_tools/nrfjprog/nrfjprog -f NRF51 -c 1000 --program _build/biketracker_app_s130.hex
Parsing hex file.
make: *** [flash] Error 58
If I try to merge the hex files for my application and the debug bootloader, that also fails, confirming there's a conflict somewhere in memory, but not where:
eliot-macbook-pro:biketracker-firmware Eliot$ /Users/Eliot/dev/nRF5x_tools/mergehex/mergehex --merge bootloader/biketracker_debug/armgcc/_build/bootloader_s130.hex _build/biketracker_app_s130.hex -o merged.hex
Parsing input hex files.
Merging files.
ERROR: The hex files cannot be merged since there are conflicts.
Here's the linker script for the NON debug bootloader:
/* Linker script to configure memory regions. */
SEARCH_DIR(.)
GROUP(-lgcc -lc -lnosys)
MEMORY
  /** Flash start address for the bootloader. This setting will also be stored in UICR to allow the
   *  MBR to init the bootloader when starting the system. This value must correspond to
   *  BOOTLOADER_REGION_START found in dfu_types.h. The system is prevented from starting up if
   *  those values do not match. The check is performed in main.c, see
   *  APP_ERROR_CHECK_BOOL(*((uint32_t *)NRF_UICR_BOOT_START_ADDRESS) == BOOTLOADER_REGION_START);
   * Currently ~18.6 kB, leaving 128.4 kB for the application.
  FLASH (rx) : ORIGIN = 0x3AC00, LENGTH = 0x5000 /* end: 0x3FC00, length: 20 kB */
  /** RAM Region for bootloader. This setting is suitable when used with s110, s120, s130, s310. */
  RAM (rwx) :  ORIGIN = 0x20002C00, LENGTH = 0x5380
  /** Location of non initialized RAM. Non initialized RAM is used for exchanging bond information
   *  from application to bootloader when using buttonluss DFU OTA.
  NOINIT (rwx) :  ORIGIN = 0x20007F80, LENGTH = 0x80
  /** Location of bootloader setting in at the last flash page. */
  BOOTLOADER_SETTINGS (rw) : ORIGIN = 0x0003FC00, LENGTH = 0x0400
  /** Location in UICR where bootloader start address is stored. */
  UICR_BOOTLOADER (r) : ORIGIN = 0x10001014, LENGTH = 0x04
SECTIONS
  /* Ensures the bootloader settings are placed at the last flash page. */
  .bootloaderSettings(NOLOAD) :
  } > BOOTLOADER_SETTINGS
  /* Ensures the Bootloader start address in flash is written to UICR when flashing the image. */
  .uicrBootStartAddress :
    KEEP(*(.uicrBootStartAddress))
  } > UICR_BOOTLOADER
  /* No init RAM section in bootloader. Used for bond information exchange. */
  .noinit(NOLOAD) :
  } > NOINIT
  /* other placements follow here... */
SECTIONS
  . = ALIGN(4);
  .fs_data :
    PROVIDE(__start_fs_data = .);
    KEEP(*(.fs_data))
    PROVIDE(__stop_fs_data = .);
  } > RAM
  . = ALIGN(4);
  .svc_data :
    PROVIDE(__start_svc_data = .);
    KEEP(*(.svc_data))
    PROVIDE(__stop_svc_data = .);
  } > RAM
  . = ALIGN(4);
  .dfu_trans :
    PROVIDE(__start_dfu_trans = .);
    KEEP(*(.dfu_trans))
    PROVIDE(__stop_dfu_trans = .);
  } > RAM
} INSERT AFTER .data
INCLUDE "nrf51_common.ld"
and the same for the debug bootloader:
SEARCH_DIR(.)
MEMORY
   * Currently ~30.5 kB, leaving ~116.5 kB for the application.
  FLASH (rx) : ORIGIN = 0x37800, LENGTH = 0x7C00 /* end: 0x3F400, length: 31 kB */
SECTIONS
  } > UICR_BOOTLOADER
  .noinit(NOLOAD) :
  } > NOINIT
SECTIONS
  . = ALIGN(4);
  .fs_data :
    KEEP(*(.fs_data))
  } > RAM
  . = ALIGN(4);
  .svc_data :
    KEEP(*(.svc_data))
  } > RAM
  . = ALIGN(4);
  .dfu_trans :
    KEEP(*(.dfu_trans))
  } > RAM
And here are the hex files for each bootloader:
bootloader_s130.hex
bootloader_debug_s130.hex
Where is the conflict? I don't see it.
Edit 1
And the linker script for the application. Note that the experimental_ble_app_buttonless_dfu example application has no .bootloaderSettings section and subsequently doesn't work. I've tried to make it work here.
SEARCH_DIR(.)
MEMORY
  /* Total flash: 256 kB (0x40000) */
  /* BUILD_PROD, larger */
  /* FLASH (rx) :                ORIGIN = 0x1B000,    LENGTH = 0x20F00 */ /* end: 0x3BF00, length: 131.75kB */
  /* BUILD_DFU_TEST, 114 kB */
  FLASH (rx) :                ORIGIN = 0x1B000,    LENGTH = 0x1C800 /* end: 0x37800, length: 114 kB */
  /* Total RAM: 32 kB (0x8000) */
  /* The Soft Device can tell us what it needs here at runtime. Run "make test" and expect a warning when we enable the SD. See:
       <SDK>/softdevice/common/softdevice_handler/softdevice_handler.c L486.
  RAM (rwx) :                 ORIGIN = 0x20002008, LENGTH = 0x5FF8  /* just under 24 kB */
/* This is copied over from the bootloader verbatim. */
SECTIONS
  } > UICR_BOOTLOADER
  .noinit(NOLOAD) :
  } > NOINIT
SECTIONS
  .fs_data :
    KEEP(*(.fs_data))
  } > RAM
} INSERT AFTER .data;
/* This is in <SDK>/components/toolchain/gcc. */
