Section 28.9.9 of the nrf51 reference manual shows the Config register has 3 defined bits, BBA. A is for Hardware Flow Control and is one bit, 0 or 1, which makes sense.
However the description for parity, which has the two BB bits, has exclude parity as 0x0 and include parity as 0x7, which would need 3 bits, not two.
Also the reset value is defined to be '100', ie a value of 0x2 for BB which is neither 0x0 nor 0x7. What is the format of this field really and what is the default reset value?
I note also that in section 28.9.10 the Reset Value of BAUDRATE (0x0198000) is none of the values in the table below it. Is that reset value correct?
