How do I integrate the DFU from the heart rate example into the BLE UART (NUS) applciation code?
I am using SDk 11.0.0 and I am trying to integrate the DFU from the heart rate example into the my code, which is based upon the BLE UART (NUS) example. When I run the heart rate example on the development kit using the Master Control Panel, I can see that the DFU service is available. However, when the DFU example code has been integrated into my code, I cannot see the DFU service available and thus, cannot select it.
I believe that I am not fully activating the DFU service. Additionally, my code causing an error on line 317 of ble_advdata.c. My uuid value contains the NUS definition, and the softdevice chokes on this. Even after I replaced the uuid value with the value provided in the heart rate example, the error went away, but I am still not able to get the DFU service to display.
Has anyone else had this problem and solved it? Is there a BLE UART example with a built-in DFU? My application has no buttons, so I need this to work.
Thank you!
