LPCOMP doesn't sense the pulse count correctly
Hii every one, We are working on a project where we are using a temperature sensor LMT01, its giving a pulse output the pulse out is from 220mV to 600m. So I'm using lpcomp to count the number of pulses. my config is like this
> Blockquote/**
 * @brief Initialize LPCOMP driver.
static void lpcomp_init(void)
    uint32_t                err_code;
    nrf_drv_lpcomp_config_t config;
    config.hal.reference = NRF_LPCOMP_REF_SUPPLY_1_8;
    config.hal.detection = NRF_LPCOMP_DETECT_UP;
    config.input = TEMP_VN_PIN;
    // initialize LPCOMP driver, from this point LPCOMP will be active and provided
    // event handler will be executed when defined action is detected
    err_code = nrf_drv_lpcomp_init(&config, lpcomp_event_handler);
    nrf_drv_lpcomp_enable();
my power supply is 3.3V as I think refrence will be 3.3/8 = 0.4125
 and incremented the pulse count in event handler
void lpcomp_event_handler(nrf_lpcomp_event_t event)
	if(event ==  NRF_LPCOMP_EVENT_UP)
		m_temp_pulse_count++;
in the span of 50ms the temp sensor giving more than a thousand pulses but lpcomp showing the output as 17. I want someone to help in this regards
Thanks in advance
