Application only starts in debug after SDK12 migration
After updating from sdk11 to sdk12, the application only starts in debug. If started with reset, it hangs. I am running on a pca10028 board an with EmBlitz 1.0. NRF51 is QFACA1 with the following linker setting:
/* Linker script to place sections and symbol values. Should be used together
 * with other linker script that defines memory regions FLASH and RAM.
 * It references following symbols, which must be defined in code:
 *   Reset_Handler : Entry of reset handler
 * It defines following symbols, which code can use without definition:
 *   __exidx_start
 *   __exidx_end
 *   __etext
 *   __data_start__
 *   __preinit_array_start
 *   __preinit_array_end
 *   __init_array_start
 *   __init_array_end
 *   __fini_array_start
 *   __fini_array_end
 *   __data_end__
 *   __bss_start__
 *   __bss_end__
 *   __end__
 *   end
 *   __HeapLimit
 *   __StackLimit
 *   __StackTop
 *   __stack
OUTPUT_FORMAT ("elf32-littlearm", "elf32-bigarm", "elf32-littlearm")
ENTRY(Reset_Handler)
MEMORY
  SOFTD (rx) : ORIGIN = 0x00000000, LENGTH = 0x1B000
  FLASH (rx) : ORIGIN = 0x0001B000, LENGTH = 0x25000
  RAM (rwx) :  ORIGIN = 0x20002870, LENGTH = 0x5790
SECTIONS
    /* You can place the softdevice in this sector so that
     * it is included in the final image.
    .softdevice :
        KEEP(*(.softdevice*))
    }> SOFTD
    /* The normal application area of the device with SoftDevice
	.text :
		KEEP(*(.Vectors))
		*(.text*)
		KEEP(*(.init))
		KEEP(*(.fini))
		/* .ctors */
		*crtbegin.o(.ctors)
		*crtbegin?.o(.ctors)
		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .ctors)
		*(SORT(.ctors.*))
		*(.ctors)
		/* .dtors */
 		*crtbegin.o(.dtors)
 		*crtbegin?.o(.dtors)
 		*(EXCLUDE_FILE(*crtend?.o *crtend.o) .dtors)
 		*(SORT(.dtors.*))
 		*(.dtors)
		*(.rodata*)
		*(.eh_frame*)
	} > FLASH
	.ARM.extab :
		*(.ARM.extab* .gnu.linkonce.armextab.*)
	} > FLASH
	__exidx_start = .;
	.ARM.exidx :
		*(.ARM.exidx* .gnu.linkonce.armexidx.*)
	} > FLASH
	__exidx_end = .;
	__etext = .;
	.data : AT (__etext)
		__data_start__ = .;
		*(vtable)
		*(.data*)
		. = ALIGN(4);
		/* preinit data */
		PROVIDE_HIDDEN (__preinit_array_start = .);
		*(.preinit_array)
		PROVIDE_HIDDEN (__preinit_array_end = .);
		. = ALIGN(4);
		/* init data */
		PROVIDE_HIDDEN (__init_array_start = .);
		*(SORT(.init_array.*))
		*(.init_array)
		PROVIDE_HIDDEN (__init_array_end = .);
		. = ALIGN(4);
		/* finit data */
		PROVIDE_HIDDEN (__fini_array_start = .);
		*(SORT(.fini_array.*))
		*(.fini_array)
		PROVIDE_HIDDEN (__fini_array_end = .);
		*(.jcr)
		. = ALIGN(4);
		/* All data end */
		__data_end__ = .;
	} > RAM
    .fs_data :
        PROVIDE(__start_fs_data = .);
        KEEP(*(.fs_data))
        PROVIDE(__stop_fs_data = .);
    } > RAM
    .fs_data_out ALIGN(4):
        PROVIDE( __start_fs_data = .);
        KEEP(*(fs_data))
        PROVIDE( __stop_fs_data = .);
    } = 0
	.bss :
		. = ALIGN(4);
		__bss_start__ = .;
		*(.bss*)
		*(COMMON)
		. = ALIGN(4);
		__bss_end__ = .;
	} > RAM
	.heap (COPY):
		__end__ = .;
		end = __end__;
		*(.heap*)
		__HeapLimit = .;
	} > RAM
	/* .stack_dummy section doesn't contains any symbols. It is only
	 * used for linker to calculate size of stack sections, and assign
	 * values to stack symbols later */
	.stack_dummy (COPY):
		*(.stack*)
	} > RAM
	/* Set stack top to end of RAM, and stack limit move down by
	 * size of stack_dummy section */
	__StackTop = ORIGIN(RAM) + LENGTH(RAM);
	__StackLimit = __StackTop - SIZEOF(.stack_dummy);
	PROVIDE(__stack = __StackTop);
	/* Check if data + heap + stack exceeds RAM limit */
	ASSERT(__StackLimit >= __HeapLimit, "region RAM overflowed with stack")
Did I miss something in migration guide? I am using ble-bcast-mesh branch master with mods for nrf52 sdk11 of mrquincle. Forgot to say: I use the bootloader feature with the switch to SDK12 which must lead to a change in the sections. This could be the reason. I am evaluating on this.
